94 mercury Tracer Trio & Ford Escort interchangeable?
Does anyone know if any of the body parts such as fenders or bumpers are interchangeable from a mercury tracer and a Ford escort. i know that these two cars are almost the same. thanks!
if the headlight housings are the same, the fenders should be too. that's usually the deciding factor. if I remember correctly, the same model years are interchangeable. the 94 should be interchangeable back to 92 as well (I could be mistaken on this one - I'm going from memory)
The headlight assemblies are definately different. That's pretty much all that seperates sister makes & models like that exterior wise, the front end and rear end. I agree with Slymer and will say the fenders should work. But did those cars have exposed bumpers in '94? Not sure if that is what you meant. I think the bumpers are covered and so they are contoured underneath to keep the nose's shape. But the larger junkyards are usually knowledgable about cross referencing and interchanging body parts like in your case. Good luck.
joeguzman10
Apr 13, 2009 10:48 AM
