Drive Axle Retaining Nut
Old Aug 23, 2010 | 07:39 PM
borgward's Avatar
Default Drive Axle Retaining Nut
Are both the left and right drive axle retaining nuts right hand thread? Can't get either side loose using breaker bar or impact wrench.
Old Sep 2, 2010 | 02:23 PM
pashadowops's Avatar
First of all, Yea they are right hand thread.
Secondly, this may sound silly but, make sure you remove the cotter pin and the retaining cap before you try to remove the nut.
Make sure you spray the heck out of it with a good rust penetrant like PB Blaster. I wound up using a socket with a 3/4 drive breaker bar and standing on it to break it loose, then I used the impact wrench.
Good luck!
Old May 26, 2011 | 05:06 PM
2512fj's Avatar
Or you can try a low tech approach and use a striking wrench.
Cheers
Old Dec 25, 2013 | 03:08 AM
have a 1998 ZX2 ... all it had was retaining nut that had part punched into a grove in end of shaft... bent it out and left car on ground to break loose... used my ratchet and bar and stood and broke it loose... needed it off to replace a wheel bearing
atomheartmother
Mar 21, 2010 11:17 PM
slymer
Aug 30, 2009 08:54 PM
bonifacioaleman
Feb 28, 2009 08:34 AM
Mk4man
Jan 16, 2009 10:18 PM
