-   Tracer (https://www.mercuryforum.com/forum/tracer-21/)
-   -   Drive Axle Retaining Nut (https://www.mercuryforum.com/forum/tracer-21/drive-axle-retaining-nut-4998/)
borgward Aug 23, 2010 07:39 PM
Are both the left and right drive axle retaining nuts right hand thread? Can't get either side loose using breaker bar or impact wrench.
pashadowops Sep 2, 2010 02:23 PM
First of all, Yea they are right hand thread.
Secondly, this may sound silly but, make sure you remove the cotter pin and the retaining cap before you try to remove the nut.
Make sure you spray the heck out of it with a good rust penetrant like PB Blaster. I wound up using a socket with a 3/4 drive breaker bar and standing on it to break it loose, then I used the impact wrench.
Good luck!
2512fj May 26, 2011 05:06 PM
Or you can try a low tech approach and use a striking wrench.
Cheers
87_Crown_Vic Dec 25, 2013 03:08 AM
have a 1998 ZX2 ... all it had was retaining nut that had part punched into a grove in end of shaft... bent it out and left car on ground to break loose... used my ratchet and bar and stood and broke it loose... needed it off to replace a wheel bearing
