I am having a problem replacing the fuse connected to the center console. I cant seem to get the old one out. I dont want to pull too hard and break something. Is there some special way to remove it? Is there a reason why it might not be coming out? Any help would be appreciated! |
If you have a small blade screw driver apply light pushing pressure outward on the side of the fuse and should come loose. |
thanks i will try that!
The early tracers have a fuse puller located on the back of the fuse box cover. Or you can get one at the local parts store for a buck or two. The puller just slips over the top of the fuse, you pinch the puller and pull and presto the fuse is out.
