-   Tracer (https://www.mercuryforum.com/forum/tracer-21/)
-   -   Hard starts Spit and Spudder (https://www.mercuryforum.com/forum/tracer-21/hard-starts-spit-spudder-421/)
brickman Feb 5, 2006 10:35 PM
I have a 99 tracer.
Hard Starts in the Cold mornings. If I try to excel at Low RPM it will sputter. It started happening about a month and a half ago andit has gottenworse over the last week. I am leaning towards Timing belt replacement and or Cleaning, replacing most parts that I can. I am guessing, somehow, the Timing jumped. I was hoping it hada chain because those have guides that go out.:(
I don't understand how the Timing belts or Timing Jumps perse,can anyone explain?
Would this be a good place to start?
Brickman
WWEB Feb 9, 2006 11:52 PM
ITS SOUNDS LIKE THE CAR IS MIS FIRING PROBABLY BA D WIRES TRY SPRAYING WIRES WITH LIGHT MIST OF WATER AND SEE IF THEY SPARK IF SO REPLACE THEM ALSO YOU HAVE A TIMING BELT NOT A CHAIN AND THEY DONT JUMP THEY ONLY BREAK HOPE THIS HELPS LET ME KNOW
brickman Feb 15, 2006 09:21 PM
Thanks, will try it.
Vtec-asskicker Aug 6, 2006 05:34 PM
also try the disturbitorcap bad plugs and or wires. try cleaning out the ignition wire with some acetone could have settement deposits the is causing a bad connection.
