knocking noise
Old Jul 3, 2006 | 02:06 AM
traci's Avatar
I HAVE A 99 TRACER GS AND WHEN I GO TOSTART IT, IT MAKES A HARD KNOCKING KIND OF NOISE AND AFTER IT STARTSIDLEING ITSTILL KNOCKS AND IT SEEMS TO BE GETTING WORSE EVERY DAY. IT KNOCKS IN ALL OF THE GEARS AND DOESNT GO AWAY WHEN YOU PRESS ON THE GAS. PLEASE HELP THANKS.
Old Jul 15, 2006 | 11:48 AM
88Tracer's Avatar
Check your engine mounts. If it's doing it when you're accelerating you could be lifting your block.
Old Aug 6, 2006 | 05:22 PM
Vtec-asskicker's Avatar
is it the tranny knocking or the engine? if its the engine your ooil is low or you have an valve leak or you could have a bad valve? im notsure about your tranny if its the problem check your oil level if its ok then you prob more than likely is a bad valve or valves.
ervinboose
May 21, 2012 01:15 PM
joeguzman10
Apr 24, 2009 11:18 AM
hdvespa
Mar 20, 2009 02:03 AM
BenRSGT
Mar 16, 2008 10:14 PM
BenRSGT
Feb 23, 2008 07:12 PM
