The Shakes
Hey I have a 96 tracer and at low RPMs it shakes and rattles like none other and that first shift out of first is real bad enough to shake the whole car but everything after that is fine until i drop below about 2500 RPM. So the question is what's wrong with my car? Is this normal or just me? its a 4 speed automatic on a 1.8L. And if you have an idea of the problem how much will it cost? :confused:
I just repaired a 1995 Tracer that rattled at idle and made noises when trans shifted. I found every engine and transmission mount was shot. I believe there was a total of 3 motor mounts and 1 transmission mount. I bought all 4 at Rockauto.com for $50 - it took a couple of hours to install them. They made a world of difference in the vibration dampening. You can inspect each mount and you will probably find the rubber insulators torn loose on every one of them.
Good Luck, Corky |
Originally Posted by corker
(Post 19305)
Good Luck, Corky Thank you |
They were fairly easy to change for me because I removed the transmission to repair engine rear main seal leak and transmission input shaft leak. The removal of all mounts can be done with hand tools, although air tools makes life easier. The first engine mount is right in front of the timing belt cover on passenger side of engine. There are 2 more engine mounts under car - they are bolted into the long black support bracket on the driver's side. One is up front and one is at the rear. If you support the oil pan with a floor jack and a block of wood, you can remove that long black engine / trans support to expose the front and rear mounts. The last transmission mount is under the battery tray. Look closely at the rubber centers of the mounts and I'm pretty sure you will see them all cracked and broken loose from the mounts.
Corky |
Corky[/QUOTE]
thank you |
| All times are GMT -5. The time now is 05:29 AM. |
