-   Villager (https://www.mercuryforum.com/forum/villager-19/)
-   -   95 airbag sensor module (https://www.mercuryforum.com/forum/villager-19/95-airbag-sensor-module-94/)
Debi Feb 18, 2005 04:34 AM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I replaced the airbag in our villager and took it in to have the light reset, etc. They said the forward sensors were bad and the module wasn't responding. Are those seperate units or is the module/sensor unit all one thing? When the airbag is deployed, do you have to replace the module? Thanks, Debbie auguys@msn.com
Windzer Mar 3, 2005 02:50 AM
Yes you have the sensers that go to the module you replaced the sensors
right?
MercAdvisor Mar 4, 2005 11:36 PM
There are sensors and there is a module is there is no communication before just replacing sensors and a module make sure they check all there wiring.
Debi Mar 5, 2005 05:02 AM
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
We haven't replaced the sensors. We know there are 2 and have found 1 under the hood up towards the front. I recall someone saying one might be under the dash, but not certain. Debbie
MercAdvisor Mar 5, 2005 11:40 AM
I know on the newer ones there is one on the core support and one on the firewall i believe the best thing i could recommend is to get a good wiring diagram for the vehicle
