Changing tire size
Old May 15, 2006 | 06:22 PM
Speeder's Avatar
Hi, new member here. I just bought a 1999 Mercury Villager with
the 3.0 engine. I am going to be using it as a mail delivery rig,
and need to put a slightly larger tire size on for puncture
resistance. Does anyone know of a way that I can recalibrate the
speedometer to be correct? I called the dealer, they say the 99
can't be reprogrammed. Thanks.
Old Feb 22, 2007 | 09:16 PM
Bowesmobile's Avatar
Well from what I know thats a OBDII system. Which you should be able to reprogram the computer via. certain scan tools. Autozone sells one for around $250.
Old Jun 22, 2007 | 03:15 PM
vanoneightteens's Avatar
How much bigger are you going? If you're only going up a little bit, it's easy to figure out how far off your speedo is, and do the math on the fly. I'm over by 3% from stock, so at 100km/h indicated, I'm actually traveling 103km/h. Here's an easy calculator to help you figure out your % difference.
MarinerTireProblems
Nov 6, 2013 09:11 AM
MarinerTireProblems
Oct 17, 2013 04:37 PM
jj_kidd
Jan 11, 2009 12:52 PM
Billy The Kid
Jun 28, 2006 01:30 AM
baraby1969
Mar 3, 2006 03:24 PM
