I have a problem with an 02 villager cruise control. works for a while the set light flashes, cruise stops working, will reset if engine is turned off and then back on. Is there a self test built into the unit, would like to run it if there is. |
I did some checking around. you may need to check the vacuum lines (if any) that go to the brake pedal deactivation switch or the switch itself. I''ve seen a few other posts online that said replacing the switch fixed the problems.
I had the issue that my cruise worked, and stopped completely intermittend. I had to turn it on (while driving) to reactivate, till it turned itself off again. Cause seemed to have been dirt below the switches. I took them out (remember, in your case, 7 years of use), cleaned them and put them back on. Now they work flawless. But BE CAREFULL: Disconnet the battery at least 15 minutes to have the airbag system come down! Greetings! |
ah... the advantages of an old 88 MGM... no airbags to worry about when working on the old beast. [img]smileys/smiley2.gif[/img]
of course, that also means no airbags to protect you in case of a crash. [img]smileys/smiley11.gif[/img] |
Well, if you get into a crash with an ''88, isn''t there a dash light telling you that you just hit something??? [img]smileys/smiley2.gif[/img] Greetings! |
| All times are GMT -5. The time now is 08:17 AM. |
