I’m hoping that someone can help me.
Old 07-07-2007, 07:33 PM
I've got a 1999 Mercury Villager. It has a digital dashboard. Anyway, every once in a while it will stop working. The speedometer just reads 0 and the odometer won't change. The tach and other things on the dash will work fine. It doesn't do it all the time.
Does anyone know what might be the cause?
Old 07-10-2007, 06:53 AM
The basics are the same, electronic gizmo, electric connections, and of course the age.
I was working on a MGM with the digital dash, which sometimes did not lid up at all.
I took the instrument cluster out, disconnected the multi-function plug in the rear (there were 3, 1 is for the main info center), cleaned the contacts, bend the plastic tabs carefully just a bit, assembled everything back together, and: voila! Works fine so far (about 9 months now).
Once something goes wrong with the electronics, you are better of buying a new cluster, unless you have one who can repair it fairly priced. However, as stated before, age and wear is a major issues to electronics, so you might want to consider this and give it a try. I wont cost you anything.
Greetings!
lchspanther2006
04-26-2012 06:48 PM
jedulh2547F230
08-14-2011 03:01 AM
dave59330
02-16-2009 08:45 PM
92Mercury
01-05-2009 07:49 PM
byran
06-10-2008 08:38 PM
Quick Reply: I’m hoping that someone can help me.
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
