Does anybody know if there is a proper way to tighten the extreme rear window on the 95 Villager..im experiencing some rattle and wouldn't want to screw it up... Thanks |
The hatch or the side rear window? |
the hatch window...
If you take off the rear door panel and check your latch assembly and see if you have any slots in that latch. If not you can shim your striker on the glass.
Thanks will do...
