2006 Mountaineer stalling
Old 04-17-2016, 08:15 AM
treasures4u1's Avatar
Default 2006 Mountaineer stalling
My engine light came on and error code is P0401 Exhaust EGR Flow Insufficient. The car is misfiring and will actually quit as I am driving down the road. I have done some research and have come up with that maybe I need to replace the GSR valve? Can anyone tell me if that is so?
Thanks
Old 05-10-2016, 08:07 AM
conan312's Avatar
It seems to me that the code Or the EGR valve does not match the symptoms you are experiencing with the vehicle itself. A frozen EGR can cause pinging and detonation. Misfiring is not a symptom of a bad EGR. The vehicle stalling definitely not. The only time I've had a the vehicle's engine cut out while in the act of driving was from a faulty crank sensor. A lot of the symptoms sound electrical to me.
Old 05-21-2016, 06:26 PM
leftoverture's Avatar
I would agree with Conan. Sounds like a professional diagnosis might be in order.
Old 01-15-2019, 02:16 PM
Jonathan Scott Brodeur's Avatar
Thanks
did you ever fix this problem? i’m having the exact same problem. ive replaced egr, 02 sensors, coil pack, spark plugs and wire set and pcv. i think i’ve got a wire chafing somewhere
Old 04-22-2019, 03:24 PM
ronaledsmith's Avatar
I've been faced the same victim around 5 months ago.
It was really awkward.
mikeasis
08-08-2018 03:05 PM
cowboy1169
06-13-2017 12:57 PM
dschutt
01-18-2014 10:38 AM
jswift
10-14-2009 01:29 PM
jenlegs
07-31-2008 02:28 AM
Quick Reply: 2006 Mountaineer stalling
