92 marquis transmission slipping problem ...
Old 09-21-2014, 05:02 PM
Paul Sharpe's Avatar
Question 92 marquis transmission slipping problem ...
92 100k marquis auto gearbox problem ... slipping into 2nd and 3rd
All fluid and such is fresh and clean and all correct.
I have a slight whining noise from a pump or something from the engine bay and had read about a front gearbox hydraulic pump pressure problem ... but there is no pump to see... that is at having a quick look. is this the problem and how to fix it or ???? any info help much appreciated.
Old 04-28-2018, 01:19 PM
Problem indicates that the Transmission Filter (Motorcraft FT-100) needs replacement.
Transmission filter inside your trans should be changed at every 30,000 miles.
Get the Motorcraft filter, and re-use the ORIGINAL pan gasket -- that requires NO RTV SEALANT !!
I installed a B&M Drain Plug Kit to make future trans filter changes quicker, easier, and with NO MESS to clean up later.
You will need to have 5-6 quarts of transmission fluid to re-fill to proper level -- DO NOT OVER-FILL !!
pooldave1
03-08-2013 07:57 PM
JSanchez830
06-28-2012 06:31 PM
BLenertz
01-23-2011 05:02 PM
New Mercury Owner
10-06-2009 04:44 PM
mady1960
05-22-2009 04:34 PM
Quick Reply: 92 marquis transmission slipping problem ...
