engine light
Old Mar 20, 2005 | 10:49 AM
beatlebug32's Avatar
hi,
my wife has a 97 mercury villager van and the engine light came on and i had an auto parts store check it for me and they said that it was the knock sensor and it cost $169.99. could some one please tell me what this is and where it is located at on the van. what will happen if you dont fix it ?
thanks rick
Old Mar 20, 2005 | 12:17 PM
The knock sensor is located on top of the engine underneath the intake manifold. Unless you have a problem with the vehicle I would not attempt to repair it itsa big waste of money. Id have the light reset and leave it alone unless you start to have problems.
Old Mar 28, 2005 | 06:16 PM
The knock sensor is for octane ratings if you use the same gas and dont hear a knock then like merc said why bother with it it can be a wast of money .
Old Mar 28, 2005 | 06:33 PM
thank you for the info . it is not knocking but when it is in drive and you come to a stop it sounds like it wants to cut out, does that have anything to do with the knock sensor ? i just put new plugs in it about 3 weeks ago.
rick
Old Mar 28, 2005 | 10:46 PM
No, but the ruff idle might have set that code. Hoping it doesn't have anything to do with any crossed plug wires [img]smileys/smiley2.gif[/img] . Try cleaning out the idle control valve with carb. cleaner, it sometimes works.
Old Apr 19, 2005 | 05:27 PM
ugothim's Avatar
also remember that the knock sensor on some models will turn off the injector of the cylinder where a knock is detected [img]smileys/smiley1.gif[/img]
214shaft
Jan 3, 2011 11:21 PM
beatlebug32
Feb 26, 2006 09:18 AM
hhray
Feb 23, 2006 12:32 AM
hdfoor
Apr 29, 2005 10:57 PM
Chris
Apr 24, 2005 01:39 PM
