mercury sable 1993 3.8
Old Sep 5, 2004 | 01:40 AM
delmarem's Avatar
Which of the computer boxes is responsible for the A/C not working?
Old Sep 14, 2004 | 02:14 PM
Do you have automatic temperature control (electronic) or analong(switches)??
Old Sep 14, 2004 | 03:36 PM
delmarem's Avatar
Ihave analong, not electronic switch: One time there was a problem with the box on the front driver side right next to the battery.
thanks for your help
Old Sep 15, 2004 | 12:46 AM
Is it not blowing any air at all or just warm air??
Old Sep 15, 2004 | 01:02 AM
delmarem's Avatar
by jumping the pressure switch on the accumulator the fan will turn on but not the compressor. By putting 12v directly to the compressor it will turn on, it seems to me, islike a relay or a diodein one of the on board computer. the meter reads voltage to the Ohhh men I've beenfighting with this for two years "Is comical" join the fun. help ok thanks
Old Sep 15, 2004 | 01:05 AM
I dont believe the analog system runs through the on board computer on that vehicle. Your best chance and cheapest start is to replace the ac relay.
Old Sep 16, 2004 | 11:35 PM
delmarem's Avatar
FRIEND! where is the a/c relay at? I am used to the old gm style relay.
Old Sep 16, 2004 | 11:44 PM
there is going to be a relay block either mounted to the left inner fender and on the right side near the firewall it should be in your owners manual.. our wiring diagrams only go back 10 years at dealers i know its in the owners manual though
Old Oct 12, 2004 | 10:29 PM
delmarem's Avatar
thanks a whole lot sorry for the delay
Old Oct 19, 2004 | 05:53 PM
I still don't know if it is not blowing at all or just warm air.(as mentioned before).
Your compressor will not run if you are low on R134.
If the fan runs in the cockpit,but no air,you are low on freon
If neither the compressor or fan run,relay,fuse,regulator,or bad harness going to comp.
