Please help my Villager
Old Feb 25, 2008 | 11:41 PM
Norcenkan's Avatar
This morning my Villager started missing. It got
worse as I drove it to work. No check engine light
came on. It started after work and did the same thing
getting worse as I drove home. I replaced the fuel filter
and it still is doing it. Enough to where it dies at idle.
Any help would be appreciated.
Norcenkan
Old Feb 26, 2008 | 01:34 AM
when it is dark outside, use a spray bottle if necessary, look at the plug wires for an electrical storm. if necessary, mist some water on wires to help see it. sounds like a plug wire might be bad or a plug is loose/bad. i have known of cars that ran like crap and plug was loose and detonated from loose plug and also because of a plug wire melted at some area causing it to arc.
Old Feb 26, 2008 | 09:03 PM
Norcenkan's Avatar
Changed plugs and wires and still running rough.
Does the 1999 villager have a coil? If so, where is it?
Thanks,
Norcenkan
Old Mar 23, 2008 | 08:48 PM
Norcenkan's Avatar
Ifound the problem. It was the distributor bearings.
They were shot. Now I have a code 1105. At least it is running now.
pooldave1
Mar 13, 2013 08:04 PM
mentalQtip
Aug 17, 2011 05:56 PM
nickoroni
Oct 17, 2009 03:41 PM
evanna
Nov 29, 2006 07:46 PM
babynhoney48
Jul 16, 2005 09:49 AM
