1998 Sable
Old Oct 5, 2004 | 11:46 AM
BFGRAVES's Avatar
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNABLE="on">
<T>
<TR height="100%" width="100%" UNABLE="on">
<TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNABLE="off">my heater only blows cold air. the heater hoses are warm going to the heater core. any suggestions</TD></TR>
<TR UNABLE="on" hb_tag="1">
<TD style="FONT-SIZE: 1pt" height=1 UNABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></T></TABLE>
Old Oct 11, 2004 | 07:31 PM
does the vehicle have a 3.0 sohc or the dohc?Edited by: MercAdvisor
Old Oct 19, 2004 | 05:40 PM
Check core and HVAC regulator. Hoses being warm could be water or ti could be air. If only air,the core will not transfer the heat.
Old Feb 2, 2005 | 04:59 PM
ugothim's Avatar
are hoses warm both going in AND coming out ? if one is warm and the other is cold then you have a bad heater control valve..which i hate to tell you is located inside of the heater core enclosure..which is a very time consuming
Old Feb 7, 2005 | 11:39 PM
Check vacum lines that control the
place the heat comes out such as
floor,def,both, might be stuck on ac
in the hvac behind the glove box.
Old Feb 10, 2005 | 04:37 PM
I have found that it is not the vacuumlines themselves but a faulty "block" that the vacuum lines are controlled by.Replace the block and you should be fine.
zman1995
Dec 21, 2010 05:46 PM
bcullen
Nov 25, 2007 12:43 PM
caddykm
Aug 17, 2007 07:54 AM
photog3740
Aug 24, 2006 02:08 PM
bas78
Mar 27, 2006 10:20 AM
