Rough Idle
Old Jun 7, 2005 | 02:44 PM
mercvill's Avatar
My Villager has a slight rough idle like a blup-blup sound at the exhaust and a slight engine shake but smooths out when AC is engaged. Runs great with AC on. Any ideas?
Old Jan 18, 2006 | 01:38 AM
Barquentine's Avatar
Well, I've only just bought a Villager, but I have a Maxima, and I
should think the Villager has a similar IAC (Idle Auto Control) valve.
These valves get gummed up causing the symptoms you describe. Remove
the IAC and clean it. The reason it runs better with the A/C on, is
that you're loading the engine, causing the idle control to move
accordingly to supply extra power, thus straightening out the idle at
the same time.
You should also clean the throttle body using carb cleaner.
disable
Feb 7, 2007 10:48 PM
ptrama
Jul 1, 2006 11:58 PM
gold mercury
May 13, 2006 01:17 PM
James
Mar 16, 2005 10:57 PM
havemustangtoo
Nov 15, 2004 03:36 PM
