93 Cougar door hinge pin replacement
Old Jul 6, 2009 | 05:17 PM
93cougarboy's Avatar
Default 93 Cougar door hinge pin replacement
I found the pins, bushings, etc... The problem is that I have no idea how to replace the old one without taking the door off. Is there any way to avoid this? Any help is greatly appreciated. Thanks
Old Jul 6, 2009 | 06:48 PM
I used a hammer and a large screw driver to bang out the pins that the bushings are mounted on, but that was on a 85 pontiac parisienne. I'm not sure about the older cougar though.
Old Jul 6, 2009 | 08:53 PM
maxfax3's Avatar
If you do one hinge at a time and support the door it can be done.. Although I think it's maybe a tad easier to just take the door off...
Old Oct 15, 2014 | 04:40 PM
Bobbydsp's Avatar
Slymer, look on the internet for instruction videos. U-tube has a lot of them. I did my left top pin by using a Dremel grinder to grind the top off the pin and driving it out with a punch.. I did my right side door pin by simply loosening the bolts on the hinge and inserting shims. My shims were suspension ones like wheel alignment people use on the a-arms. Worked perfectly.
Bobbydsp
searchlight4759
Nov 14, 2013 11:26 PM
jongs
Jul 6, 2013 08:53 AM
Aubrey Burleson-Sanford
Apr 10, 2012 12:20 PM
don1957
Jul 6, 2009 08:51 PM
Sheila K
Mar 26, 2008 05:57 AM
