1999 grand marquis wipers
Old Apr 9, 2006 | 06:49 PM
JoeB's Avatar
The wipers on my 1999 grand marquis only work on high speed. When
switching to any other speed it sounds like a clicking sound comming
from the dash. I am trying unsuccessfully to troubleshoot this
problem and would appreicate some assistane. thanks
JoeB
Old Apr 18, 2006 | 05:05 PM
libertylm's Avatar
It sounds like a switch to me. I tend to try and stay away from electrical problems. Have you tested the switch?
Old Apr 18, 2006 | 06:51 PM
JoeB's Avatar
I am not sure how to test it.. And I agree so I guess I will make it a dealer fix..
Old Apr 19, 2006 | 12:23 AM
ITS PROBABLY THE WIPER CONTROL MODULE WHICH IS LOCATED UNDER THE DASH RIGHT OF STEERING COLUMN SEE IF THE ORANGE WIRE GOING TO MODULE HAS POWE WHEN PUTTING WIPERS ON LOW THE MODULE HAS 12 WIRES GOING TO IT ALSO THE DARK BLUE WITH WHITE IF THEY HAVE POWER GOING TO MODULE REPALCEMODULE IF NOT REPLACE SWITCHGOOD LUCK HOPE THIS HELPS
Old Apr 19, 2006 | 12:35 AM
JoeB's Avatar
If I understand your correctly WWEB, the BLUE with white and the
organge are te ones to check for power to determine if it is the switch
or the module.
Thanks
Old Apr 19, 2006 | 12:52 AM
YES THIS IS CORRECT
Old Apr 19, 2006 | 10:10 PM
JoeB's Avatar
Look like it is a dealer fix, I could not find any blue/white wire with
an orange wire connected to the same thing.. From the Fuse there was a
brown and green wire.. thanks though.
Old Jun 3, 2024 | 06:43 AM
woofcat's Avatar
Default 1999 Mercury Grand Marquis LS Wiper Problem
I have the same problem and working through shop manual.
Looking at 1999 module Ford F5AF-17D541-AB and spare module from1993 Grand Marquis (55000k) which reads FordF3LF-17D539-AA.
Wires and pins are the same. Any chance that they are interchangeable?
I also have the 93 multifunction switch and motor.
Appreciate any help in helping me get rid of my Mercury Blues.
99 Merc 116000k
Thanks
tundrawolf
Feb 8, 2010 01:50 PM
Wipers123
Mar 28, 2009 12:08 AM
96mercurygm
Mar 24, 2008 11:23 PM
daniele
Jun 8, 2007 07:18 AM
TerryA
Jul 12, 2006 01:08 PM
