90 Sable SW turns no start
Old May 20, 2006 | 01:26 PM
mooserun's Avatar
1990 mercury sable SW - automatic -3.0L
I was driving home the other day as I approched stop light car stalled then would not start. got towed home. When i try to start it turns but won't start. sorta like a battery that need charging. anyway , I have replaced the battery, alt. checked ok, starter checked ok, starter relay selenoid replaced, ignition module & ign. coil replaced - still not start. Also oil change, filter, plugs & wire ,dist cap basic tune-up stuff done a few months ago.
Is there a way to check/test the Neutral Safety switch?
When I turn the key to start you can hear the fuel pump power up - but possible that it is bad?
Any ideas would be appreciated.Thanks[img]smileys/smiley1.gif[/img]Edited by: mooserun
Old May 30, 2006 | 07:49 PM
Billy The Kid's Avatar
put it in gear and try to start it.you should hear nothing
Old May 30, 2006 | 07:50 PM
My sable just started to do that a few nights ago. I have to let it sit a lil while then it restarts
Old May 30, 2006 | 09:54 PM
I just talked to a friend about My problem and it sounds similar to yours. He suggested I change the fuel filter. I hope that fixes both our problems
Old Jun 3, 2006 | 11:47 AM
mooserun's Avatar
No -it does not start - no matter what.
It is not getting any spark. and I have already replaced the ign.coil ,ign module ,dist. cap & rotor , has new plugs & wires etc.
someone mentioned something about a "pick-up" it goes on the distrib?
has anyone heard of it ? can it cause my issue?
Old Jun 10, 2006 | 09:02 AM
maybe a crank sensor?
Old Jun 13, 2006 | 03:52 AM
mooserun's Avatar
where is the crank sensor located?
Old Jun 16, 2006 | 07:04 AM
located at either end of the crank. it acts like an eye to see if the crank is spinning, how fast it's spinning (revolutions per minute or R.P.M.'s) so if thatsensor goes bad it can't tell the computer that the crank is spinning. hence no spark. you should begetting fuel if you hear the pump priming andgiving fuel pressure when you turn the key on. you haven't run the car out of fuel lately, haveyou?that could clog the intank strainer or fuel filter.try replacing the pick up coil if it has one.cam sensors can do the same as a crank sensor if they were to go bad. good luck.
Momoftwosonsintrouble
Jun 11, 2011 09:59 AM
Jun 10, 2011 07:41 AM
jason sereiko
Jun 20, 2008 09:04 PM
sideway
Aug 27, 2007 06:18 PM
Vanzilla
May 21, 2006 02:32 PM
