95 airbag sensor module
Old Feb 18, 2005 | 04:34 AM
Debi's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I replaced the airbag in our villager and took it in to have the light reset, etc. They said the forward sensors were bad and the module wasn't responding. Are those seperate units or is the module/sensor unit all one thing? When the airbag is deployed, do you have to replace the module? Thanks, Debbie auguys@msn.com
Old Mar 3, 2005 | 02:50 AM
Yes you have the sensers that go to the module you replaced the sensors
right?
Old Mar 4, 2005 | 11:36 PM
There are sensors and there is a module is there is no communication before just replacing sensors and a module make sure they check all there wiring.
Old Mar 5, 2005 | 05:02 AM
Debi's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
We haven't replaced the sensors. We know there are 2 and have found 1 under the hood up towards the front. I recall someone saying one might be under the dash, but not certain. Debbie
Old Mar 5, 2005 | 11:40 AM
I know on the newer ones there is one on the core support and one on the firewall i believe the best thing i could recommend is to get a good wiring diagram for the vehicle
Reborn
Aug 24, 2014 08:15 AM
unit731
Feb 23, 2014 12:25 PM
Morphin
May 29, 2010 06:30 PM
danielleakamom
Feb 4, 2008 04:49 PM
baraby1969
Feb 9, 2006 11:25 PM
