-   Capri (https://www.mercuryforum.com/forum/capri-22/)
-   -   1993 Capri Automatic, non turbo, blown timing belt! (https://www.mercuryforum.com/forum/capri-22/1993-capri-automatic-non-turbo-blown-timing-belt-10610/)
markjs Sep 8, 2019 12:02 PM
As I understand it it's a non interference design? Just blew blocks from home, snapped completely, no horrendous noises, just stopped running.
A few questions; first, I can't get the dipstick out? is it just pushed in with o rings after you remove the support bracket?
How will I get the harmonic balance nut torqued? Will I need to get the flywheel through an inspection plate or do I need to go borrow a specialty tool from O'Reilly's?
BTW this car has one munch on the front bumper but will be for sale cheap if I get it running. I have an '84 Subaru I love because it's 4wd and dead simple (pushrod/timing gear engine, yay!)
markjs Sep 8, 2019 01:06 PM
OK, seem to be getting away without removing the dipstick, but this gasket is terrible (timing cover gasket).
The challenge is getting the intake cam to stay in position while I get the belt on now. I am trying to enlist an assistant to hold it in place.
Still curious how best to torque the balancer after?
ptt12 Jul 29, 2021 07:22 PM
Impact wrench should put enough totque to it. Whats the torque setting for the Harmonic Balancer anyway?
