1990 Cougar vibration coming from somewhere?
Old Feb 24, 2011 | 07:02 AM
jd2010's Avatar
Default 1990 Cougar vibration coming from somewhere?
I started having a vibration coming from somewhere. I tried checking the bellhousing bolts and u-joints, but both were good. The vibration starts at first acceleration and goes up to about 60 miles an hour. The vibration I just started noticing a couple days ago. I wonder if driving in slushy snow has anything to do with it. When I did this a couple weeks ago, the throttle started to not respond. Like it wouldn't depress. I looked at the cables and they looked ok to me, but I couldn't depress the accelerator. But, like I said that was a couple weeks ago, and I doubt that would be the cause of the issue. I can't tell if the vibration is getting any worse, but I have noticed the vibration is starting earlier when I drive the car. Any suggestions. I hope you can help. Keep up the good work.
Old Feb 28, 2011 | 10:53 PM
94cougarxr7's Avatar
the trans mount i will check that recently i had to replace mine do to the same problem. it ended up tweeking the tail of the trans and i had to replace mine. see if you can wiggle the trans it self as in it will teater
Old Mar 2, 2011 | 07:03 AM
jd2010's Avatar
Yes, this was my next thing I was going to check. I did check the tranny mount bolts, but all were tight. Thats when I seen that there was a lot of oil on the tranny mount. I'm pretty sure the oil has deteriorated the rubber on the mount. I hope this is the fix. Thanks for the response suggestion is well appreciated.
Old Mar 18, 2011 | 03:45 AM
mercuryman92's Avatar
Default about ur post
have you checked too see if the weights have fallen off of the drive shaft, if one has fallen off that will cause a viberation ...
Old Jul 27, 2011 | 05:48 PM
jd2010's Avatar
Default problem found
It was a rusted rear u-joint on the drive shaft. I grabbed this u-joint and rotated it back and forth on the drive shaft, and it felt as if it was good. When I took the drive shaft down, I could tell immediately the u-joint was froze. One of the bearings was so dried out from water entering the cap.
Old Aug 17, 2011 | 07:28 AM
i am glad you were able to fix it i had the simular problem with mine with the u joint.
dvtsj
Sep 2, 2012 10:44 AM
Xavier210
May 23, 2011 08:54 AM
CarChick
Feb 13, 2011 01:56 AM
k8cpa
Nov 30, 2010 10:10 PM
jd2010
Oct 12, 2010 07:35 AM
