1996 Cougar xr7 4.6L
Old Jan 30, 2009 | 06:35 PM
berrywalker11's Avatar
My 1996 cougar doesn''t have reverse or neutral. Both reverse and neutral drive forward instead of what they are suppose to do. The trans. seems to work properly though when hooked up to a computer by a mechanic. What could cause this?
Old Feb 1, 2009 | 05:51 PM
the linkage from the shifter to the trans is too tight or hung up on something and needs to be fixed. sounds like it''s actually in neutral when you have it in park.
Old Feb 5, 2009 | 06:19 PM
Well it also starts going forward in reverse and neutral without giving it any gas, can that also be because of the linkage?
Old Feb 5, 2009 | 06:23 PM
It can''t be the linkage because underneathe u can see it shifting into the gears
Old Feb 6, 2009 | 11:39 AM
I didn''t say the linkage was broken, just in the wrong position. unless you know that the position that it''s in is supposed to be in specifically for each and every gear, then the position may need to be adjusted.
ERNurse
Aug 10, 2011 05:06 AM
jacob1234
Sep 16, 2006 11:34 PM
jacob1234
Apr 23, 2006 12:51 AM
COUGARNUT
Apr 22, 2006 03:09 AM
jacob1234
Feb 18, 2005 05:53 PM
