More 90 cougar issues
Old Jul 27, 2011 | 05:58 PM
jd2010's Avatar
Default More 90 cougar issues
My car started having this problem of starting hard several weeks ago. It turns over but faster than normal. I recently had the fuel pump in the gas tank replaced along with a new fuel filter. I thought I was having a leaking fuel injector because sometimes there would be a puff of gray smoke coming out of the exhaust that would smell like gas. I got the fuel rail out and turned over the engine, but no fuel injectors leaked so no luck there. Could a faulty ignition module cause this hard starting problem? I do have 80K miles on this rebuilt motor maybe spark plug wires and plugs are due, along with distributor cap and rotor. Any help would be appreciated. Thanks in advance.
Old Aug 17, 2011 | 07:35 AM
94cougarxr7's Avatar
i would do the same thing do the basics first it could be one of the plugs fould out and not sparking right. after that if it did it again i would check if the egr or the fuel perssure is ok i think it might be both the fuel pressure regulator could go bad and fould out some thing or not burning when the plugs not burning the extra fuel. i would do the spark plugs first. then see what happens my favorit plugs to use is e3 because i noticed a better performance as well as better aconomy out of my v8
Old Aug 18, 2011 | 06:36 AM
jd2010's Avatar
Found the problem. It was the fuel pressure regulator. A friend mentioned it may be the problem, I changed it and it fixed the issue. Thanks for the reply!
Old Aug 19, 2011 | 07:17 AM
not a problem i seen you post and no one replied i wanted to mentioned what i will check
pacdog
Sep 7, 2023 09:08 PM
92mercurygm
Sep 2, 2011 01:25 AM
cougarowner
Sep 20, 2007 12:17 AM
alex32288
Apr 19, 2006 10:30 PM
Vanilla
Nov 9, 2005 03:43 PM
