grimmallan |
09-11-2013 09:07 PM |
1991 mercury capri starting problem i cant figure out
my 1991 mercury capri non turbo has 104k on it. at first it would start to pop off then die and crank without popping off again. then you could shut it off and wait for 5 minutes then do it all over again. by passed injector shut off cause it was getting constant spark, and with the injector shut off still did same thing. would start to pop off then die. replaced fuel pump because it was weak. now you can hear the fuel pump run. if you let it sit a bit then try to start it it will pop off then die and if you just keep doing that for 10 times in a row without letting it sit, it will then after about the 1oth time will then start, idle to about 1500 rpm then die. then it will just keep doing that. if you hit the gas it will do a sharp rev then die at 1300. then if you let it sit for about 5 minutes you then all over again have to let it pop off about 10 times before it will start revving then dying. fuel pump stays on whole time it starts dying. so its not dropping fuel and not dropping spark. because pulled a plug and checked. any ideas?????????
