-   -   91 grand marquis sensor (https://www.mercuryforum.com/forum/general-tech-help-12/91-grand-marquis-sensor-101/)
ranman Feb 22, 2005 09:51 PM
I am getting a code 54 Intake Air charge temperature sensor fault
its blowing black out the exhaust and hesitating to an almost stall at times while driving
its a 5 litre 302 fuel injected
where is the sensor located
cctxfish Feb 23, 2005 05:00 PM
There is something wrong here. I'm not sure of the code, but the 5.0L doesn't have a IAT sensor it has a engine colant temp sensor. Now the 4.6L engine does have a IAT. So am thinking you got a 4.6L, and if it goes bad it will cause those semtoms.
Autozone has this website that has limited use, but good info when its there. check out:
http://www.autozone.com/servlet/UiBr...rdPage=az/cds/ en_us/0900823d/80/17/48/db/0900823d801748db.jsp
Windzer Mar 28, 2005 06:25 PM
Think about the smoke not the code ?
or black oil or smoke ? what is it oil?
woodson Oct 6, 2005 12:22 PM
I have a 1990 Mercury grand marquis, I can drive the car for about
thirty minutes then the car stalls out, then won't start until the engine cools down. Please help.
