98 mercury tracer wont start
Old Jan 2, 2006 | 07:19 PM
mommykaren's Avatar
hello hope someone can help me. my tracer has a 2.0 engine. was running fine made it halfway up the drive and stopped. we have check timing belt. it is fine. fuel pump is working, we put in new plugs and wires. they are working and getting spark. it seems like the fuel injectors are not working at all. when you use the starter fluid it will run but stops when not using it. could this be a sensor? does anyone have any suggestions. Please help[img]smileys/smiley19.gif[/img]
Old Jan 3, 2006 | 02:58 PM
Patrick's Avatar
Administrator
did you have a cel before this happened?
Old Jan 17, 2006 | 02:35 PM
conan312's Avatar
well it sounds like you definately are not getting fuel to the engine. you say the fuel pump is working. try changing the fuel filter. if that does not work take the filter back off and see if fuel is actually making it to the filter. if no gas appearsit might be a clogged strainer in your fuel pump. has the car been run out of gas lately? has your check engine light ever come on? good luck.
ddh052286
Feb 22, 2011 08:22 PM
hparies
Aug 17, 2010 06:00 AM
dvpotgieter
Jul 17, 2010 12:28 AM
SomeGieka
Mar 20, 2009 11:09 PM
jodypaul
May 10, 2006 03:37 PM
