Engine light on and off
Old Sep 28, 2009 | 06:39 AM
jharb76's Avatar
Default Engine light on and off
Hello
I have a 1990 Sable and while driving to work today my engine light went on and off many times. When the light was on I would lose some power and once the light went off I would regain full power. Does anybody know why this would happen and how I can repair it?
Thanks for reading my post!
Old Sep 28, 2009 | 09:27 AM
kwolfeman91's Avatar
I would go to autozone and let them check your car they test it for free....
Old Sep 28, 2009 | 09:32 PM
definitely get the code read (it should keep it in memory unless you pull the battery off for a few). That will help greatly in diagnosing the problem. without the code, it's really a shot in the dark to find the issue.
Old Oct 5, 2009 | 03:21 PM
conan312's Avatar
your loss in power is the engine or dimming lights and such, too?
Old Oct 5, 2009 | 11:06 PM
crazyrog17's Avatar
On an old car I had, a flashing check engine light meant no oil pressure. It happened a lot at stop lights and would stop when I took off. The pump needed higher RPMs to get the oil moving through the clogged pick-up which I eventually cleaned out.
First thing's first: Check your owner's manual to see what a flashing check engine light could mean. Get to autozone as soon as you can to see what they say and in the meantime before you drive it again, check all the fluid levels for saftey's sake.
Old Oct 17, 2009 | 03:48 PM
nickoroni's Avatar
did you notice if you used more gas then normal, the 94 sho did that all the time, on for awile then off, changed o2 sensors no problem after.
GARMASTERS
Jul 28, 2015 01:43 PM
rocasan
Oct 23, 2012 01:36 PM
rocasan
Oct 23, 2012 01:12 PM
214shaft
Jan 3, 2011 11:21 PM
jason sereiko
Jun 20, 2008 09:04 PM
