| cabits |
Feb 21, 2006 12:54 PM |
I have an engine miss that I can't find on my 91' Marquis with the V8 5.0ltr HO mods. I Replaced the following.....plugs, wires, cap, rotor, coil, fuel pump & filter, fuel pressure regulator, ACT, ECT, TPS, new distributor and spark control module. The miss is not constant it comes and goes. I have no codes showing. It doesn't matter if its a bumpy road, rainy day, etc. It does it most right when the temp is about to open the thermostat or just after it opens. I never notice it when its idling. Did a cylinder balance test and it passsed. It doesn't seem to be at any certain engine speed but is more prominent when under a load or big hill. The miss is usualy only a one time miss then a minute later it will doo it again just once. Kinda like the key is being turned off and on shutting the engine off for that split second.
