ignition key lock cylinder
Old Sep 14, 2008 | 08:34 PM
jwcaylor's Avatar
Key does not go into ignition smoothly. Have lubricated does not help. I want to remove the cylinder but can not get it to release. I have removed the plastic cover from the column. I am told with Fords you can insert the key turn it half way and push a release button through an access hole. I can not locate a release or remove the bottom plate to gain access to the cylinder. There is a triangular shaped plate at the bottom of the casting but I can not get it off. Does anyone have experiance with this. Car was built as a joint venture between Mazda and Ford called autoalliance. <BR itxtvisited="1">
jwcaylor
Sep 9, 2008 10:09 PM
Chanel63
Jun 11, 2008 01:25 PM
forkliftrman
Mar 4, 2008 10:12 AM
pkucan
Jan 3, 2007 08:51 PM
SableCat
Sep 10, 2005 08:12 PM
