-   -   Necessary Parts to remove from a 99 Grand Marquis (https://www.mercuryforum.com/forum/general-tech-help-12/necessary-parts-remove-99-grand-marquis-9445/)
66GoldenFiinnedComet Oct 29, 2017 05:16 PM
Hi everyone!
I need insight on what parts should be removed from my Mercury which is no longer running, to keep for my new Mercury.
I had a 99 Grand Marquis and I loved it. The engine was still running strong and then I was told the frame was rotting out and I was operating on borrowed time. In the meantime I loved my Grand Marquis so much that I went and bought an '01 which is in pristine condition.
I just had the front end re-done on my '99 so I am going to have all of those parts removed. (They are less than a year old).
The list of parts I came up with are by category
Front End:
Control arms
Sway bars (I think?)
Upper and lower ball joints:
Engine:
Intake manifold (relatively new)
Coil Packs (relatively new)
Spark plugs and wires
Alternator
Battery (relatively new)
Fuel pump
Exhaust:
O2 sensor
Catalytic converter
Wheels/New Tires
Do Mercury Grand Marquis have any problem areas/parts I should remove for my new Mercury? Any other ideas will be greatly appreciated!
Thanks!
JosephJet Nov 1, 2017 06:48 AM
INTERCHANGABLE pARTS
New member and I cant figure out how to make a new post, but i have a question on just about the same topic as the OP... i.e. interchangeable parts.
I have a 99 Grand Mar. I think the build date was Nov '99. I have become aware that part way into the model year Mercury started installing a somewhat never front brake and rotor set up. Rotor is larger and pads may be larger and the spindle is a little bit different.
My question : Can the newer, larger brake set up ( spindle, rotor, pads) be installed using the existing controls arm/ (suspension/swing arms) or does these upper and lower control arms suspension components have to be changed also?
I was at the junkyard and the control arms "look" to be same?
Thank you.
