Need help replacing Airbag Control Module 7E53-14B321-BB
Old Jun 21, 2017 | 11:02 AM
Junie Cordero's Avatar
Default Need help replacing Airbag Control Module 7E53-14B321-BB
Hello I have a 2006 Mercury Milan I was in a accident and the steering wheel airbag deployed.I am in the process of fixing and need to replacing the Airbag Control Module 7E53-14B321-BB... However when looking for used I noticed that the part numbers are different on some. Is there a way to tell if compatible? The one I am looking to install part number is 6E53-14B321-BJ
Will this work? Any help will be appreciated. Thank you
Old Mar 29, 2021 | 06:12 AM
Chad Griffin's Avatar
Default Update?
I am restrting this old post in hopes that someone has the answer. I am dealing with the same isue. I have a 2007 fusion se and the rcm I took out is the "7E53.." part number, but the good one I got to put back in is the "6...blah,blah" part number that you mentioned. Both part numbers are compatible with 2007 fusion. I'm just curious if it worked or not.
Dale
Jan 28, 2018 11:02 AM
unit731
Feb 23, 2014 12:25 PM
srch4aresn
May 18, 2011 07:12 AM
Morphin
May 29, 2010 06:30 PM
danielleakamom
Feb 4, 2008 04:49 PM
