Single action hydraulic spring compressor
Old Nov 15, 2009 | 01:40 PM
Default Single action hydraulic spring compressor
ya know those single action spring compressors for coil springs...
Anyone know of a hydraulic version?
all the spring compressors out there that's I've found so far are for struts or with very little clearance for a side grabber type. with the fat control arms on the old MGM, you have no chance of using those. The screw down version does work. but takes an hour just for one spring with a breakover bar. Apparently I'm too much of a wuss to be able to do that while laying under the car with it as high as it will get off the ground on jack stands. I poop out after about 40 minutes of cranking and the springs still aren't quite compressed enough to help with replacing the control arm bushings.
Old Nov 24, 2009 | 09:58 AM
Thought so... Looks like I'll have to find a 2-5 ton hydraulic ram (pull type) and cannibalize a single action spring compressor to create my own.
Old Dec 2, 2009 | 05:19 AM
dimekind73's Avatar
Thanks Dan, I appreciate it. Ill give you a ring for the 3/4 heims for the shackles...Are your spring plates customable? Or one size fits all?
Old Dec 2, 2009 | 08:20 PM
wrong thread maybe?
Old Dec 4, 2009 | 11:39 AM
D.Aroke's Avatar
I'll probably just buy them. I'm guessing you are using the pro tools 105 dies?
Old Dec 23, 2009 | 06:29 AM
Aftedia09's Avatar
im after a bush thats 40mm wide with an 18mm shackle pin hole... does anyone know if a bush is made at that size... if not whats the closest size with an 18mm hole
they are for a 50mm wide spring
arela
Oct 21, 2013 06:31 PM
chamsey
Oct 21, 2013 02:28 PM
mado
Sep 21, 2013 11:34 PM
johndem1x
Apr 24, 2012 09:06 AM
Chromenut
Jun 1, 2009 03:38 PM
