03 Grand Marquis Directional problem
Old Apr 29, 2009 | 04:19 PM
Briankos's Avatar
Default 03 Grand Marquis Directional problem
The right side directional flashes faster than the left. Checked all the bulbs on both sides, and all are functional. Am I missing something? I hear that the flasher is a built in unit and cannot be replaced. Anyone else have this happen? Is there a mystery bulb somewhere I am not seeing? I have not replaced any of them so a wrong bulb is ruled out.
Old Apr 29, 2009 | 05:35 PM
double chck tails byr removing and checking filaments... might be good to check fronts also... usually a fast flash means bad buld on the side it flashes fast for... my older cars just light and dont flash ... at least they did before i replaced with all LED lighting in entire car and swapped flasher...
Old Apr 29, 2009 | 08:21 PM
BFM70's Avatar
Agreed. It is almost always a burned out bulb causing that, but it can also be a short in the multi-function switch in the steering column. Mine will occasionally do that only when signaling a right turn and I can correct it by giving the turn signal stalk a little wiggle.
I really should fix it, but it happens so rarely I don't really worry about it.
Old Apr 29, 2009 | 09:31 PM
maxfax3's Avatar
Thanks for the info BFM.. My 96 has been doing that for years.. Never really bothered to investigate it untill you mentioned jiggling the handle (now I think of a toilet when signalling) It seems I have the same issue.. And it'll probably get fixed if it quits all together...
Old Apr 29, 2009 | 10:22 PM
BFM70: I had the same problem with my wife's 93 vic. I HOSED down the hazard switch (top of the column on that car) and the turn signal switch with some contact cleaner. haven't had the problem since and it's been about 3 years now since I did that.
don239
Aug 12, 2009 12:24 PM
bots444
Dec 18, 2008 08:26 PM
merccenduro442
Sep 15, 2008 10:57 PM
roaddogg
Aug 7, 2006 01:03 PM
