03 Grand Marquis LS won't shift out of park-
Old Nov 8, 2017 | 05:24 PM
Indymom46060's Avatar
Default 03 Grand Marquis LS won't shift out of park-
Hi there ☺
03 Grand Marquis LS wouldn't shift out of park & had no brake lights. Brake switch replaced - brake lights now work, but still won't shift out of park. Any ideas or advice would be much appreciated!!
Thanks in advance !
Old Jan 12, 2018 | 07:55 PM
Davesnothereman's Avatar
Default Maybe this will help.
Originally Posted by Indymom46060
Hi there ☺
Thanks in advance !
Its the shift interlock I am sure you have heard this. If you need to move or drive it all you need to do is put the key in the ignition turn it to the first click move gear lever to neutral and start it. You can drive it but every time you put it in park it will lock up again. So you have to do the same thing again. You put in a new brake light switch thats usually it. Check and make sure you have enough brake fluid and you have no leaks or bad brake line. Check fuses also. Anything to do with braking will lock out the transmission so you cannot move. Hope this helps.
jec
Nov 11, 2017 06:45 AM
72Blazerod
Jan 21, 2012 05:46 PM
Sharper
Oct 3, 2011 09:38 AM
rekab3
Jun 1, 2005 06:57 PM
