1988 Grand Marquis Heater Problem
Old Dec 18, 2005 | 08:24 PM
roaddogg's Avatar
Not getting any heat out of the heater but both inlet and outlet hoses to the heater are hot. Still can not get any heat through the vents. Get alittle warm air when in the defroast position. Themostat and water pump have been changed. Any ideas?
Thanks for your help.
Old Jan 6, 2006 | 03:48 PM
conan312's Avatar
does the fan blow any air at all? or just cold air?
Old Jan 7, 2006 | 05:34 PM
WWEB's Avatar
do you have manual a/c or elec contol?
Old Jul 30, 2006 | 08:34 PM
1breaux's Avatar
Look for a hot water valve that may be stuck closed. It is located on the heater hose from intake. It may be stuck closed. I suggest replacing it. 8 to 10 dollars is a reasonable price.
Old Aug 7, 2006 | 01:03 PM
kayakfish's Avatar
Hey I have a 1992 and had the same problem ended up replacing the heater modulater 800.00 later, you have to take the intire dash loose and replace the thing. Good luck[img]smileys/smiley5.gif[/img]
jordanc
Nov 30, 2013 11:46 AM
gearheadmike
Oct 10, 2011 06:50 PM
88marquis
Oct 19, 2009 11:30 AM
COOPERATIVE
Sep 21, 2009 12:02 PM
Ritzbury
Jul 8, 2008 01:46 PM
