1990 GM 5.0L Another spark plug ?
Old Feb 16, 2013 | 06:32 PM
bobtucson's Avatar
Default 1990 GM 5.0L Another spark plug ?
Hello experts, my "new" 90 Merc is in dire need of plugs. Got the left side in w/o to much trouble. Right side very obstructed. The question is should I take off the air components, check valves, valve assembly and hoses for access?
The one plug i was able to get a wrench on (rear) was frozen and I don'w want to break any with poor angles on the wrenches. Penetrating spray is applied, just need the experts system.
Help appreciated,
70 yr old guy with tools
Old Feb 17, 2013 | 02:22 PM
EddieE's Avatar
I use either a spark plug socket that has a swivel end attached or spark plug socket with a universal attached...then I attach that to various extensions combining to get a length just right to slide between things from a higher height to get the proper angle on the plug. Extensions with "locking" socket ends are handy too. When you install the new plugs just add a touch of anti-seize to the threads to make them easier to remove next time.
Guy who has spend too much time working on Ford's/Mercury's
Old Feb 17, 2013 | 02:51 PM
bobtucson's Avatar
Default Thanks Eddie,
I'll give it another try, maybe penetrating spray has taken effect.
Thanks again, appreciate the help,
bob
Old Feb 19, 2013 | 06:07 PM
bobtucson's Avatar
Default Success
Just a wrap up in case someone else has this trouble.
The access issue is solved by loosening and removing the air hose to left side manifold pipe.
Unbolting the air valve and this lets you push the whole assemble out of your way. The right rear was frozen and two nights of penetrating spray and switching to a 1/2 in drive for more torque did the job.
Thanks,
Bob
bob
Terry
Feb 17, 2019 11:26 AM
Sparkplugs.com
Sep 1, 2017 03:22 PM
Smokefan
Apr 24, 2009 07:55 PM
andrew65
Jan 24, 2009 05:53 PM
gordoj52
May 9, 2007 03:43 PM
