1991 MGM Fans + Radiator
Old May 25, 2010 | 12:59 AM
Stealthlead's Avatar
Default 1991 MGM Fans + Radiator
Hello,
I have a 1991 Ford MGM and I live in Gilbert, Arizona. My car does great until its idle in 100 degree+ whether. It has a good water pump, thermostat, good coolant, not leaks, good hoses, etc. I noticed there is no fan in front of the radiator, and it still has the metal clutch fan. I was going to start out replacing the metal fan with a plastic one as I hear its easier on the engine, and also install a fan on the front of the radiator/air conditioning condenser. If that doesn't help I was also thinking of replacing the radiator as its a bit old.
I'm looking for suggestions on what size/type/kind of fan I should be installing in the front of the radiator, what fan to replace the metal one with and a new radiator if it comes down to that also.
Thank you for your time,
~Stealthlead
Dennis Paige
May 30, 2014 10:07 AM
nnnmm
Jul 16, 2013 11:01 PM
ionosphere
Feb 19, 2008 09:58 PM
PELICAN
Jan 10, 2008 04:55 PM
83,94 Marquis99
Dec 6, 2007 03:31 PM
