1995 Grand Marquis EGR Valve Replacement
Old May 22, 2019 | 06:02 PM
JamesLConner's Avatar
Default 1995 Grand Marquis EGR Valve Replacement
Take off throttle house vacuum hose EGR VALVE vacuum lines assembly Vapor Canister Purge Valve bracket passenger front tire screw and bolts holding the wheel well cover pipe wrench unscrew EGR Tube nut EGR valve 10mm bolts is on an angle Valve and Tube comes out together use 2 pipe wrench to unscrew Tube from EGR valve. Hand tight valve then put Tube in from underneath and hand tight Tube exhaust nut align everything then wrench tight. Good luck.
Old May 27, 2019 | 11:14 AM
Default '95 Grand Marquis EGR Valve
Whenever attempting to access the EGR Valve, much time and trouble can be avoided/eliminated by FIRST removing the entire windshield wiper assembly.
Removing the wipers and the wiper motor housing allows access to the EGR system and related parts.
Remove Wiper Motor Housing to Gain Access to EGR System
cowboy1169
Jun 13, 2017 12:57 PM
hocman123
Apr 18, 2010 07:43 AM
NH_USA
Apr 4, 2010 08:13 AM
jswift
Oct 14, 2009 01:29 PM
MItoplock
Sep 19, 2008 10:59 PM
