1995 Marquis coolant leak
Old Feb 7, 2012 | 02:39 PM
dmerc95's Avatar
Default 1995 Marquis coolant leak
I have a 95 marquis LS with 178K. I bought the car about a month ago. After having the car foe about 1 week i noticed the tem guage was running high. I checked the coolant and it was real low. I topped it back off with 50/50 coolant. Ran fine and problem seemed to be that it was just low on coolant. Well 2 weeks later i noticed that coolant is leaking for under the car just before the oil pan. I checked the coolant level and it again was very very low. I dont believe it is the water pump nor thermostat or hoses. Im not sure if its a freeze plug (hope not) or a broken heater hose or bad heater valve. Any suggestions ?
Old Feb 15, 2012 | 09:27 PM
billccm's Avatar
This car has the ByPass hose that runs under the intake manifold. You are at the mileage that these fail. Unfortunately, you will have to remove the intake manifold to replace this hose. Good Luck, Bill
Old Feb 16, 2012 | 04:02 AM
martinez's Avatar
this is the same problem even i am facing can any ine suggest me the best.
eeek2014
Nov 13, 2014 04:24 PM
fastframebelair
Sep 27, 2013 01:40 AM
tonyhodge
Sep 12, 2011 12:28 PM
the james
Jul 17, 2011 03:55 AM
JedClampett
Jan 18, 2008 11:37 AM
