1995 Mercury Grand Marquis
Old Mar 2, 2006 | 02:12 PM
jlsimons's Avatar
I am trying to remove the door panal of the left front door. I need to replace the lifting arm for the window. I need help I can not get the panal off.
Old Mar 7, 2006 | 01:06 AM
AngelD's Avatar
There could be just screws, or screws and clips. Are they power windows? If so, unscrew the panel holding the switches first, then pry it off and disconnect the cable. If manual windows, remove the crank. Then look for anywhere between 4 to 6 more screws, behind the door handle (the screw may have aplastic tab covering it that you'll need to pry off as well)and at the bottom of the door. At the bottom of the door is where the clips might be. Take off any screws you see there, then try to pull the panel towards you just a little bit and in the same motion push up. Don't force it, becauseyoumight strip the hole where the clip is fastened. Ifthe panel doesn't come off fairly easily, then there's a good chance you've missed a screw - maybe under the armrestor anywhere else on the panel.
txrob779
Jun 14, 2017 03:09 PM
tacmed
Jun 14, 2017 02:25 PM
NBIMPORTS
Jun 14, 2017 02:22 PM
discernment
Jun 13, 2017 01:49 PM
Project1948
Jun 29, 2012 11:24 PM
