2002 marquis check engine light
Old Dec 27, 2012 | 03:44 PM
2002merc's Avatar
Default 2002 marquis check engine light
in my grand marquis i had a vacum problem so i replaced the tp sensor the idle air control valve and the evap purge solenoid. i drove around for about 20 min and the check engine light came back on so i took it to autozone to read the code again and it said that the tp sensor was bad again. is it possible that i got a bad sensor. should i disconect the batt for a while to reset the computer.. i aslo had some other codes come up the first time i got them read.. a cylnder 8 misfire,purge or vent valve was bad, or bad tp sensor. like i said i replaced the purge solenoid and tp sensor and the misfire and purge solenoid codes were gone and the tp code came back. please help.......
Old Dec 27, 2012 | 10:16 PM
bluemonster's Avatar
It is always possible to get a bad sensor. Take it back to AZ ands have them replace it.
214shaft
Jan 3, 2011 11:21 PM
olds97_lss
Jul 6, 2008 02:12 PM
damercga
Dec 31, 2006 05:24 PM
hdfoor
Apr 29, 2005 10:57 PM
Chris
Apr 24, 2005 01:39 PM
