2003,2004 cobra rims. will they fit?
Old Oct 26, 2008 | 01:45 PM
jason sereiko's Avatar
Will 2003,2004 cobra rims fit on my 1998 MGM? does anyone know whay years fit without having to use spacers? I know the cobras are different from the regular mustang, so any help would be great.
Old Oct 30, 2008 | 09:11 PM
BFM70's Avatar
I think the Cobra rims have a little more backspacing...which should make them just about perfect for the MGM. Which style wheels you thinking about?
Old Oct 31, 2008 | 09:17 PM
Hey brother,
Thanks for the tip. I just was not sure because the cobra rims are a lot wider than the Mustang stock rims.
I was thinking of putting on the 2003 chrome rims on.
Old Oct 31, 2008 | 09:32 PM
BFM70's Avatar
You will need to be careful with your tire selection.
A stock 03 Cobra rim at 17x9 will be very near flush with the fender lip, which will look absolutely killer!!! If you use the Cobra tires (275/40-ZR17) they should clear, but you''ll need to cycle the suspension to make sure they won''t rub the fender lip when the suspension compresses.
Old Oct 31, 2008 | 09:47 PM
BFM70's Avatar
To put it into perspective. If you look at my car, your set will be 1 1/4" wider and nearly 2" taller with virtually the same offset.
Old Jun 9, 2019 | 10:47 AM
Jacobfisk's Avatar
So you guys are saying I can fit 275 40 17 tires on a 9inch cobra rim. On my 2002 mgm?
Old Jun 10, 2019 | 09:53 AM
Default 275 x 40 x 17 Tires & Wheels
The SUGGESTION was made -- 11 years ago. There's no evidence to show that those tires & rims will actually fit on the car without interference with the body, chassis, or suspension.
1. - The 9-inch wheels with that size tire WILL hit the front Stabilizer Bar on the INSIDE edge of the tire.
2. - A 275 mm tire is 11 inches wide -- too wide for front tires -- poor (dangerous) handling will result.
3. - 11-inch-wide tires WILL aquaplane very easily. Can't drive in the rain. Or the snow.
4. - That wheel and tire combination is EXPENSIVE -- are you SURE you want to spend so much money on something that will NOT improve your Grand Marquis comfort, ride, safety, performance, or economy ??
5. - The 17 x 7-inch Mercury alloy wheels would be your best choice -- they'll fit right and function, too !
The 95 MERC has 15 x 6.5 alloy wheels from a '92 Lincoln Limo, with Mercury Hub Caps. Wheels made in Italy.
Classic Style "Italian Lace" Wheels. Goodyear ComforTread Touring Tires.
tfriggs
Aug 17, 2022 11:39 AM
stoveboat
Dec 24, 2009 02:44 PM
atx_deuce
Oct 27, 2008 07:08 PM
bkbigf0ot
Apr 13, 2007 12:34 PM
publicenime1
Oct 3, 2006 12:23 AM
