-   -   2004 GM air conditioning dead (https://www.mercuryforum.com/forum/grand-marquis-14/2004-gm-air-conditioning-dead-5529/)
hugh9222 Apr 10, 2011 01:45 PM
My GM lost it's A/C this morning. Nothing works. No fan in any position including 'Vent' and compressor clutch is not kicking in. I can hear the duct door actuators operate. HELP!! Hell is coming to Texas any day now"<>@#!
Thanks. Hugh
hugh9222 Apr 15, 2011 04:27 PM
I'm still trying. Replaced the 40A fan blower fuse and the clutch relay. Of course neither worked. NEW question. Would this type of failure show up in a scan of the error codes, ie would a dead AC unit throw off a code?? Thanks, hugh
hugh9222 Apr 23, 2011 11:14 AM
Problem(s)(?@#!) solved. First the fan relay (located somewhere under the dash/mechanic) went out and therefore no fan. Second, I was low of freon so the clutch would not kick in. All it took was money to solve it. I'm at a loss that the fan relay is not in the same under hood electric box as the clutch relay?? I hope this helps someone else. Hugh
