-   -   2007 Won’’t start after fueling (https://www.mercuryforum.com/forum/grand-marquis-14/2007-wnt-start-after-fueling-1851/)
tcm1 Jun 28, 2008 04:26 PM
So far Mercury mechanics said they have never heard of this problem and have failed to correct this, and will easter-egg it even more. Car is a 2007 Mercury Grand Marquis GS with 12,500 miles and started this with only 600 miles on it. Car starts normally until the gas cap is removed(for refueling). Then it only starts when cranked for 3 or 4 tries and only if you keep cranking and continuously pumping the gas pedal, then it slowly rises in rpm''s (on the tach). Then it will "catch" and rev up to 3000 rpm. Hold it above 1500 rpm for a minute. Then two pedal it and keep it above 1000 rpm when putting in drive. It will want to stall until driven a few minutes at 35 mph. I figure its the vacuum system not right and causing the new-fangled expensive injector/plug parts to be "vacuum locked" in the fuel delivery. Does anyone else have this problem?
jason sereiko Jun 28, 2008 07:44 PM
First,you should never have to press the gas pedal on a fuel injected car when starting it. You will burn out the plugs. You only do that on carburated cars.
Are you refueling the car with it still running or taking off the cap when the car is still running? if so it sends a code to the emissions computer and causes the car to have to be started after 3 cranks to burn off running fuel vapors.
Check your plugs, you might be getting too much gas on them by pumping the gas pedal when you start it and this is what after the plugs get hot the cars runs better. This can also be caused by the fuel pressure being inconsitant and doing it throught he computer
tcm1 Jun 28, 2008 11:04 PM
If you just crank it over, it never starts, you MUST keep the gas pedal moving in order for the computer to put fuel to the engine; must lose its idle brain and only apply an acceleration signal to the fuel injectors. There are no "plugs"...these are integral fuel injector/coil/plug assemblies; unlike you''ve ever seen before...don''t equate to earlier setups....don''t know what the book officially calls them, I call them "The $500 spark plugs, another billiant idea".
Experiment 1: Car idling at 700 rpm, remove gas cap...engine idle revved to 1500, then settled back to about 800 rpm. Put cap back on (no fuel added), after a few seconds idle returned to 700 rpm.
Experiment 2: Fuel up with car in idle. Car idling about 700 rpm, removed gas cap, revved and settled as before in experiment 1. Adding fuel...first i added fuel too fast (half way open on spigot) car started to lose idle and strained to keep running. Immediately stopped fuel flow, car recovered after about 30 sec and returned to normal idle. Slowly added fuel until that point was reached and then backed off fuel flow until car ridled normally (about 1/4 open on spigot).
And setting the A/C on has no affect on the above starting...so computer also doesn''t step up the idle it for the above starting.
Mercury mechanics replaced the "vacuum control module" and car acted normal for one week...then back to the original problem. On earlier models we called it "the starship enterprise". It is the vacuum /pressure switching for the gas tank lines from the carb to the charcoal bed when running / off.
tcm1 Jun 28, 2008 11:09 PM
OH, I forgot....
Cap was always removed about 3 to 5 minutes after turning the car off...time to walk in, stand in line, pay for gas, and return to the pump.
jason sereiko Jun 28, 2008 11:23 PM
tcm1,
I am thinking it is a good thing it is under warranty. You might want to talk to the dealer mechanic manag:ment. go online and find out about "the lemon law". let them know you intend on getting a law suite for this car being unfixable if they can not fix it and make sure they give you a rental car for free. Sometimes it gets them scared because Ford usually will not reimberse them for over1 year when they lose in a law suite because they could not fix it.
with a car being this new and under warranty it is best to not fix anything yourself because you can be held liable. It is an easy way out for them. I have seen it done before to people because the dealer knows the ford company will not reimberse them. Email me and i can help you with info on the lemon law. maybe we can get this fixed if we scare them
jason sereiko Jun 28, 2008 11:30 PM
some times you can have your car insurance guy write a letter explaning that you intend ongoing through with the lemon law if they do not fix it. if you have a good insurance guy he can put you intouch with the right lawyer for freeor he can just give you a letter and it is enough for them to fix the car the correct way. make sure they compensate you with a rental and you are not charged for miles.
tcm1 Jun 28, 2008 11:53 PM
Jason, Thanks...I''ve let them know the last shop visitthat this is the official beginning of prep for the lemon law to apply. Next Sat is the next appointment, with rental car at their expense. I have a 3yr bumper to bumper warranty, so there''s plenty of time for them to waste thousands of Ford''s dollars; which I''ve told them too in that "after Ford wastes a few thou and I waste manhours and expense and inconvienience bring it here, maybe you''ll decide to buy it back and make it a 2 ft cube." But they are in the denial stage...it''ll take a few more visits and mega bucks before they think otherwise.
Actually I like the car...wish they could finally fix it...just wish I could be a normal person when fueling...its a pain to wait for the end pump, or an out of the way pump, to be empty while getting looks for not just using an empty pump; so I can push it forward out of the way if/when it don''t start, and then getting many snears when it finally starts and I have to rev it and keep it rev''d until I drive it for awhile at 35 mph.
Other than the embarrassing and excruciating refuelings (one time I''m sure will be its last refuel in its original assembled life - boneyard after that)...its a great car.
jason sereiko Jun 29, 2008 12:03 AM
I am sorry you got a bad one. These are great cars,sometimes and not that often, this hapens to every kind of car in the millions they make. I hope it works out for you. The best way is to show them a letter saying you are going to pursue a law suite and then they know you are not playing around. It really does not matter if they are in denial, when the letter is in there hand they will fix it right away.
Good luck
tcm1 Jun 29, 2008 12:07 AM
And I gave them an option at the shop...
Rip out this driveline and drop in a 1965 289 or a 1968 302; remove all the computer junk, and I''d be more than happy....
I grew up rebuilding those drive trains...and can work on them in my sleep. Was two weeks away from being certified Ford mechanic before Nam came along for me.
But none of their mechanics knew what I was talking of....too bad we have lost so much skills.... and they have become mindless slaves to computer error codes...with little to no troubleshooting and analytical skills of their own...just the easter egg replace and see approaches...
tcm1 Jun 29, 2008 12:13 AM
And I love it when I tell them a $4 broom handle will tell them more about whats going on than any $50,000 computer....and then I show them and explain every noise they hear as we work our way around the drive train...
Always get a kick out of that, andtheir surprised expressions when they first hear the sounds and can''t believe it is that simple...and when I explain what different problems will sound like, different from the normal sounds, and which parts are bad or wearing out...
Well thanks for your help and advice....
