2008 grand marquis ls running bad pls help
Old Sep 9, 2018 | 12:59 AM
Lazasco1's Avatar
Default 2008 grand marquis ls running bad pls help
So I'm having weird issues with my car it runs good as long as I don't step hard on the gas the second that I step on it even just enough to overcome someone it acts like it wants to stall and actually revs dow!! The second irelease the gas pedal it goes back to normal also if I drive it for a long period of time during hot summer days it stalls everywhere and acts like it has no power also I get a weirs smell like if I have been running it hard . This doesent happen during winter on cold weather it runs way way better . It has a code p0193 Fuel Rail Pressure Sensor I have changed it already and still have the same problem anyone knows what's going on please help
Old Sep 9, 2018 | 04:41 AM
raski's Avatar
I would start with the basics. Have you changed the fuel filter recently? I would also check fuel pressure on the rail, a failing fuel pump won't be able to deliver proper volume and pressure at peak engine demands. Finally, I would pull the vacuum line off the fuel pressure regulator and see if there is raw fuel present there which would indicate a ruptured diaphram. I am a firm believer of diagnosing first and not go out and start replacing things (except for maintenance items) and hoping to get lucky.
Old Sep 9, 2018 | 03:50 PM
Replace the in-line fuel filter with Motorcraft #FG-800.
Old Sep 9, 2018 | 09:50 PM
Lazasco1's Avatar
fuel filter Is new
Old Sep 9, 2018 | 10:02 PM
Lazasco1's Avatar
i have replaced the fuel filter and I don't like replacing 100 $ sensors with out knowing what's wrong nether but I need a computer program that can read my cars fuel pressure it has return less fuel so it has no where to connect a gage in the fuel lines that's wy I replaced the part that my code reader pointd out also I know a faulty lfuel pump can cause no power issues but I have been having this issue for over a year and it has never refused to start it only acts up in hot days
Old Aug 8, 2023 | 01:49 PM
flackbait's Avatar
Get it a full scan by a shop with the hardware and software to do it or buy a sophisticated tablet scanner . Scotty Kilmer has a list of of approved scanners. Don't throw parts at it.
Rayy
Sep 3, 2019 04:22 AM
PurpleFuzzies
Aug 24, 2018 05:43 PM
chrisreed26
May 13, 2011 10:34 PM
Harvest Gold
Oct 9, 2008 08:06 AM
wizkid
Sep 15, 2008 10:50 PM
