2008 MGMLS 4.6L PCV Valve
Old Oct 9, 2008 | 09:22 AM
DuffyBoy's Avatar
Apparently Ford has come up with new PCV scheme. The PCV valve seems to be fixed in the valve cover on the passenger''''s side. Also has an electrical connection to it!! There are two catches at the base that seem to lock in the valve cover. And it doesn''''t want to come out very easily. I just don''''t want to trash this valve trying to get it out.
Question is: Has anyone removed this valve yet? I normally remove my PCV valves at each oil change and shoot SeaFoam thru to clean the valve, upper intakeand upper cylinder area.
Thanx,
DuffyBoyEdited by: DuffyBoy
Old Oct 9, 2008 | 07:18 PM
BFM70's Avatar
Interesting. I have not seen that yet. Couldn''t you feed your solvent in through the brake booster''s vacuum line and accomplish the same thing?
Old Oct 10, 2008 | 07:44 AM
DuffyBoy's Avatar
That would get the upper intake and cylinder area and not the PCV. Thru the PCV gets them all. That''s the way I do it on 02 F150 and 94 TC.
Old Oct 10, 2008 | 11:58 PM
BFM70's Avatar
My question would be why do you use so much sea foam?
I was just looking at the MSDS on that stuff and it appears to be little more than naptha and isopropyl alcohol in a light oil. Seems to me that too high a concentration mixed in the crankcase could potentially harm the bearings.
ansky926
Nov 12, 2014 08:31 AM
1997sabledude
Feb 8, 2009 07:31 PM
tinkertom
Apr 19, 2007 03:18 PM
lkmfcars
Mar 9, 2007 06:58 PM
jserrent
Apr 23, 2006 07:43 PM
